Hi Fellas,
97 4x4 CCSB ZF-5 parked since 2014. Just installed New 205/30s jectors, new performance HPOP, up pipes, turbo, retro fit IC, 6.0 E-Fuel (with cold fuel recirculating circuit removed) pump, with regulated return and fuel filters changed fresh fuel, fresh oil, new batteries.
Upon cranking, tack moves, No Diagnostic Trouble Codes, fuel system is primed and pump is running, however pressure is not registering at regulator, which is set at 65psi +-.
AutoEnginuity scanner initially says 54% IPR duty cycle, RPM is 165, injection oil pressure is way low until 13 seconds of continuous cranking then HPO jumps to 2460 psi and duty cycle drops to 34%. Fuel injection is 0.04ms once 2460 HPO is reached then pulse width is 0.32ms. Injector buzz test all injectors are firing strongly. All relays and fuses have been cleaned and greases with dialectic grease.
Thinking I still have air in HPO system as it should be at 2400 psi almost instantly not 13 seconds of cranking. Using stock files with no Hydra installed yet, IDM is 120 volt unit, GP relay is a White Rodgers (Stancor) 200 amp unit.
Suggestions welcome.
