1 - 2 of 2 Posts
Truck ran good for about 25 min then stalled while driving. Replaced fuel filter and then started right up again. Drove for 5min and stalled again. Now it just cranks and wont fire. Any help would be appreciated
Check the oil level. Is the CEL illuminated? Does the tach move while cranking? Check the fuel pressure while cranking (should be at least 25 psi). You can check it at the shrader valve on the driver's side of the fuel bowl with a cheap "stick type" tire gauge (just use a rag around the joint to avoid getting sprayed.. Cheers!
1 - 2 of 2 Posts
