1 - 12 of 12 Posts
Premium Member
Dont know why he needs the last digits on your vin......
I dont need them if you buy the glowplugs through us and we offer free shipping too.
Sure it's an ok deal. Saves you about ten bucks... big whoop.
When replacing them do you also need to replace the valve cover gasket?
The vc gaskets are reuseable. Look them over to make sure they are not burnt or anything like that...
Discussion Starter #9
Got the plugs ordered. Hope they are an easy change. Hope nothing breaks and gets stuck in it.
Stirn Again
Just had mine done on the 2000 193,600 on the OD 2 were dead and 3 were out of resistance.These were original glow plugs
$88.00 from Riff Raff had free shipping in Nov
You might need to replace the harness that attaches to the top of the glow plugs and plugs into the valve cover gaskets
they are plastic caps that tend to crack with age and heat mine were good but had new ones and replaced anyway the valve cover gaskets were in great shape and no need to replace them
K when I tear it apart I will look at it all. I dont use this truck a lot so when I tear into it is not like it needs to be done right then. Mine is a 96 with 118,000 orginal miles.
1 - 12 of 12 Posts
