1 - 2 of 2 Posts
Got a zf5 s42, I was driving the other week and I never had a second gear till this day it shifted in and when I shifted out the shifter and handle read second but tranny was stuck in second. Took top half off trsnny and put it in neutral. What's the deal? And a second issue I'm having is I have to hold the shifter in third or it will pop out and grind. What could be causing that? Thanks.
Hannibal
Not an expert on transmissions, but, experiance says this is a shift fork issue. 2 of them in your case. 1-2 fork and 3-4 fork. Not that it matters. Either way it has to come out for repair. Up side... both going out at same time is a blessing. Change them all while your at it. Probable Cause, (I hope) previous owner was a gorilla and damaged it by forcing it to find the right gear. Otherwise its a weakness in that model.
Converting my MD5 to the zf due too similar issue and light/heavy duty concerns. 5-Reverse fork. no 5th and kickout on reverse.
1 - 2 of 2 Posts
