1 - 20 of 32 Posts
Complete drivetrain from a 95 f-250. Tree fell on the truck. I was going to use this in a project vehicle but plan on going a different direction on it. No idea on miles. I do have the gauge cluster though, but it has a digital odometer.
manual trans, manual shift transfer case. Turbo was recently replaced. Radiator, wiring harness, ecm, etc. available as well.
$2500 obo. Dont be afraid to make a reasonable offer. Not looking to split it up right now.
Located in Charles Town, WV.
(3o4-279-2o21)
Not looking to split up right now as I said.
If you buy it for what I'm asking, you get everything I pulled from the truck. Wiring harness, ecm, idm, gauge cluster, all accessories/brackets, motor mounts, etc.
If I remember correctly, the glow plugs and 2 injectors were replaced somewhat recently as well.
OBS Addict
if you were closer and willin to split it i'd buy the trans and t-case from ya, be nice to convert my 2wd to 4x4
I've got a dana 60 front end available as well. Wont be sold until this is sold though.
no, its just upside down in the bed. drivers drop, high pinion, balljoints.
I can deliver for $2/loaded mile up to 250 miles also.
3000 with the axles.
front will need brakes and backing plates.
3000. you get a free engine and stuff with it.
read my post next time buddy.
ok BUDDY was not aware the other has not sold.... Also figuring you want 2500 for the motor and tranny that means 500 for axels huh BUDDY...
dont be a dick, was just stating that I had already posted that the axles were not being sold separately unless the engine/trans sold first. I was not trying to come off as an ####### if that is how you took my response.
and $500 for them is only if they go with the rest of the stuff.
Discussion Starter #16
we have a 94 f250 with a 351/non-zf manual trans we are probably going to part out soon if they will work?
Had a buddy at Ford check for me. The parts are the same.
How much for the whole assembly, clutch and brake pedals, and aluminum bracket under the dash shipped to 49224?
I attached a photo of what I need.
Also looking for a tilt column w/floor shift for the same truck.
Discussion Starter #19
let me figure out how big of a box and a weight and I'll let you know.
I believe it has a tilt column as well, I'll check next time I'm at the storage yard.
Discussion Starter #20
Up.
Haven't gotten the parts together to figure out what shipping is going to cost yet regarding those pedals.
1 - 20 of 32 Posts
