1 - 3 of 3 Posts
my 95 has been cranking a little longer for a week now. and yesterday it wouldnt start at all unless is was cold. i replaced the fuel filter and the CPS. Any other ideas that would cause it to crank without starting when warm?
Sounds like ipr orings, 17$ fix. The typical problem is that but take the plug out of the oil tea when hot and see how much oil is in there. Should be really low from drain back. If its full then you have a high pressure oil issue
1 - 3 of 3 Posts
