1 - 3 of 3 Posts
A guy I know is having this issue, it drains after sitting overnite..causing starting problems
. Is this the front cover drain back issue?, I've seen the write-up. He has a new hoop and new ipr also. What else could be causing this?
Was the replacement HPOP the same as his old one or was it a newer one? The later HPOP on an an earlier front cover will have drainback issues. Cheers!
I'll ask him, so its possible that his new HPOP is a stock replacement for a 95 causing the problem, I wouldn't be surprised if his mechanic did this. I told him to get a adrenaline or a SD pump
1 - 3 of 3 Posts
