1 - 5 of 5 Posts
I have a 95 f250 7.3 that just recently started cutting out on me it’ll run great and then all of a sudden acts like it’s running on 4 cylinders then run great again. Any ideas would be greatly appreciated. Thanks in advance
Check the wire harness connectors on the valve cover gaskets, you may have burnt pins on the connectors
Sent from my SM-J737V using Tapatalk
I got it it was two wires grounding out together at the drivers side injector connector on the valve cover thanks for the advice she’s purring like a kitten now
1 - 5 of 5 Posts
