1 - 3 of 3 Posts
Truck just started doing this sometimes, It will just crank but not fire. Can try her 5 or 6 time before she'll start then runs rough for a minute. Does not do it all the time just once and a while. Will a filter do this, weak fuel pump or is it the HPOP. Any tests i can do or is component swap only.
Thanks in advance
Yee yee
I had this problem with my 97 psd and it turned out to be the fuel pump in the engine valley. And the fuel heater element in the fuel bowl. There's a little air thing on the side of the fuel bowl and if I pressed the little pin in for awhile it would let out air and she would fire right up. I drove her this way for awhile but it sucked.
<---Peggy Sue
Sounds like it's sucking air somewhere
1 - 3 of 3 Posts
