1 - 3 of 3 Posts
I have tryed everthing and it just wont start im getting good fuel pressure new cps new fuel filter iv checked and rechecked fuse #22 and nothing it cranks and smokes but wont start im out of ideas iv tryed just about it all any ideas ????
whistle tits
Checked engine oil level? Checked hpop resovoir level? Tried unplugging icp sensor and cranking? Does the icp sensor have oil in the plug? Checked ipr tin nut/ ipr harness/pigtail? Are you getting a wts light? Does your tach move while cranking? Oil pressure gauge on dash moving while cranking?
Oil is good and fresh hpop is filled I unplugged the icp cranked it no start pluged it back in no start battery are good fuel is at a good level no check eng light tach moves cleaned icp harnessing and no codes on the scanner im checking the ipr tomorrow morning but looked at it and felt hand tight
1 - 3 of 3 Posts
