Hi all,
I'm currently restoring a 1994 D60 to swap into my 97 250. I ordered a new stub shaft from Amazon and the specs checked out but now that I have it next to the original D60 stub, it is definitely a much smaller part. Seller said fits D50/D60 f250/f350 which I have read elsewhere these stubs are interchangeable although it doesn't seem this way.
With that being said, I am now considering just using the original D60 part but my concern is that when I pulled it, the spindle bearing was toast and it had also worn down and created some grooves on the surface the bearing rides on.
Can I use this shaft or is it too chewed up? This truck will probably be put in 4WD a handful of times.
Thoughts on both predicaments?
Thanks
Thanks
