1 - 2 of 2 Posts
I have a 93 Ford F-250 that had a sagging front end from being used as a plow truck. I threw in a Rough Country Add-A-Leaf, which leveled the truck out nicely. The problem now is it has a fair amount of positive camber, enough that it is visibly noticable. when I bought the kit from JCWhitney I was told it would not need any correction. I took it to the alignment shop and they wanted to replace the tie rod ends and put in new Camber bushings. I would like to do most of the work myself, and just have the shop align it when I am done. Does anyone know where I can get the adjustable camber bushings for a decent price? I am replacing tie rod ends now and will be getting to the bushings next. Anyone done this before and have any tips or know where to get the bushings?
Thanks
Premium Member
thast the bad thing about the dana50TTB front axle found under the f-250s.... they are really only good on a stock springs, adding an add-a-leaf or a lift kit using that axle usally ends with bad results.
1 - 2 of 2 Posts
