1 - 20 of 21 Posts
matt
i got a stack kit and was looking under there and there is a crossmember right where the stack goes, do you just cut a hole in it or what??:confused:
I Love Work'N On Hot Rods
Are you referring to the u-channel brace on the bottom of the box??
matt
no its on the frame. it about 12'' wide. yours didnt have that?
Maybe mine didnt interfear with my kit. I guess, I will have to go look under my truck again and see if I can tell what you are referring to. Sorry I cant be of more help. I was going to say if it was the bracing for the bed to just drill right through it but if it is the frame then you are probably going to have to either go in front of or behind it if you can.
matt
ill just notch it out thanks for the quick replys guys!!
Yea the more I think about it, I think I just notched mine out a little to let the 90* elbow fit.
matt
must of been awhile for you
Yea it has been a little over a year since I installed my stack. I also purchased everything separate. I'll go look at tomorrow.
matt
thanks im gonna try to get mine put on this weekend
Is it a single or dual stack kit??
matt
single
Yea man I like the single stack. It makes the most sense IMO since we have a single outlet coming from the turbo. Now if we had two turbo outlets then absolutely I would say do dual stacks. Not to mention you can still run some stuff all the way forward in the bed where you really cant with duals. JMOs.
matt
Discussion Starter #14
yeah i agree its a single black stack.
nice
i notched mine with a torch when i did mine back almost 6 years ago.
matt
Discussion Starter #17
i think im gonna go after it with a saws-all and make a notch
Ok so I went back out and looked under the truck and my elbow doesnt interfere at all with the cross member of the frame. It appears that the elbow goes behind it about an inch or so. IMO I would see where/how much it would contact with that cross member and as long as you arent cutting out more than half the width of it, then you should be ok. I guess I would have to see how much contact it was making to give you a better opinion. Hope this helps.
matt
Discussion Starter #19
will do thanks for the info
Caterpillar Tech.
I think it depends on what kind of mount you use to hold the stack
1 - 20 of 21 Posts
