How much more power are you wanting?
there are some simple things you could do like a chip (may be hard to find one for mercruser spasifcly but may be able to get something) or some sensor foolers, then you could bugrade turbo, injectors, and on and on.....
I guess the first thing you'll have to figure out what kind of computer system it has on it, ford or international. they will probably look the same but may have some diferances in tuneing
there is no electronics on the motor 2 put a chip i already have a manual boost controler it has a Schwitzer 166735 turbo good for 44psi n 530hp and i can turn up the fuel looking 2 do nitrous wwas wondering if anybody knows if there is a wet nitrous system out there for diesels
any info on those motors? i heard the injectors were bigger than a trucks. i mean 270 out of an idi w/o smoking out the world is awesome lol. i didn know they made them that new. stanedyne(sp) injector pump or other?
I would give Hypermax a call. They were one of the first to hop up the IDI's. You can get a higher output injection pump.
Have you increased the fuel of your factory pump and bumped up the timing any? Those are the simple and "free" things you can do to increase power. Other than that you are looking at bigger injectors, aftermarket pump, internal motor work.
