CJ, sorry for bring up a dead post, but, do you happen to have the part numbers you used for the bellhousing, flywheel, starter, and clutch?
One can do worse in digging up old posts
. You should start your own project thread and lay out what you are attempting to do.
Bellhousing - Ideally you will get this with the transmission so I don't really have a part number...
Flywheel housing - this is the adapter that you need. The flywheel housing bolts to the back of the 7.3 and "houses" the flywheel and clutch. The bellhousing/transmission then bolts to the flywheel housing. They came behind International versions of the 7.3. I'd look for junkyards that sell medium duty truck parts (or bus parts). Just find a truck with a 7.3 and it should have a usable flywheel housing.
Flywheel - I believe mine was made by IAT (Illinois Auto Truck) PN 1818214c91 - make sure the flywheel is a 10 bolt.. There is a similar version for the old 7.3/6.9 engines.
Clutch - IAT NMU747-024-2 - this is for 1.75 diameter input shafts.
Starter - DB Electrical - do a search for 228000-7371 - This should be the starter out of an International 4700 with a 7.3.
Cj
And Welcome to PSN!
