What info are you looking for. I dont have any codes but seems to be progressively getting worse as i drive it
No, nothing is necessarily the culprit! We don't have enough information.
Do you have a scanner capable of reading the Ford Heavy truck protocols? If not, get FORScan.
Are you just saying the fuel filter is "good", or did you look at it and see? IF the fuel filter is dark, that MAY point to injector rings.
White is excess fuel, blue is oil. Generally. Generally.
Nothing can be stated specifically because we don't have enough information. If you don't feel like getting FORScan, see if you can rent a scanner or if a parts store will scan it for you.
