GOOD MORNING AMERICAAAAA! And ford men of this tough old world.
Well we started pulling the 7.3 from the 96 dully. What a job for a shade tree HEEE HEE HEEEE!
If any one would be so kind to offer some prayer and or advise (free) we would be much obliged.
First off we could not get the fan clutch off the water pump snout. we took off all the bolts holding the pulley to the snout and this didn't release the clutch, i guess it's not 2 pieces. how do we separate the clutch and fan from the water pump snout.
After we removed the radiator and everything bolted to the engine and took care of the transmission cross member and driveshaft, broke the motor mounts loose we could not get the engine out because the turbo would hit the firewall dash topside and the oil pan would not clear the cross member. does the oil pan have to come off or does the turbo have to be removed. were trying to remove as little as possible because we won't have to remember where it went back.
Last but not least how in the world do you get the fuel feed lines separated. There is some kind of connection (acme tool!!) lower left hand side.
Man what a day it would have made a good beer add. You know what i mean,Hee Heee He.
