1 - 3 of 3 Posts
I have 180/30 injectors in my 7.3 and I’m wanting to do some supporting mods to get the full potential out of the motor. I don’t have a huge amount of money so I’m torn between a Adrenaline HPOP or a gtp38r. My question for you guys is which of these mods would give me the best bang for my buck. Looking forward to hear what you guys have to say
If you are going to get a whole new turbo, then you need to skip the 38r and get a KC300x. If you want a little of both things, then get the adrenaline and then get the balanced assembly and 360 rebuild kit from KC to put on your stock turbo.
  • Like
Reactions: JCart
Depending on your usage, where you live, differential gears, tire size, you might consider an A/R 1.0 housing too. Will increase low end performance and quicken up turbo spool in the 1600-2200 rpm range.
j
1 - 3 of 3 Posts
