1 - 5 of 5 Posts
Have a 7.3 Idi and it's refusing to start.
Ran when parked a year ago, managed to get it to run for 5 minutes right away on the old diesel and then it sputtered and died.
Managed to get it running one other time starting on ether and it ran until we were out of fuel in an aux tank, about 5 minutes. Lots of smoke and it was wide open reving at 1500rpm.
Now it starts and dies and won't continue to run no matter what I try.
Have replaced return line cups o rings and injector seals, new lift pump, new fuel filter.
Getting power at fss and confirmed it is moving as well as the metering valve.
The lines seem bled but they aren't getting a ton of gas coming out at the injectors.
I also towed it for 5 km in gear to get it to warm up and start but no dice, this was before the new fuel pump though.
I'm stumped. It's a super cool quad cab and the cab is in great shape. Only 150k km on the Odo.
Premium Member
welcome to PSN.
how much fuel is in the tank?
these trucks are known for the pickup tube in the tank cracking and sucking air.
IDI Dude
Unhook rubber line at lift pump, remove tank caps and apply compressed air (not more than 90 PSI) and listen for gurgling... my TSV (tank selector valve) is clogged enough to where if I switch to the other tank, engine loses rpms and dies...
It's so clogged with asphaltines (small black particles that look like showerhead pieces but are not-whole 'nother subject) that the TSV is jammed and I plan to take it apart and clean it when I install 38 gallon tank in.
The Ford whiz kids thought it was cool to locate the TSV right in the space between front tank and frame rail and nobody can get to it without dropping that tank with the skid plate.
I have a Facet pump with a line filter right before it and have to change it every so often because it is getting clogged with tiny hard black pieces of asphaltine. When I change the line filter (way cheaper than changing the canister filter on top) I have to blow back and clear the line so the new line filter (see through) doesn't get clogged right away.
So anyway, try blowing the lines back to the tank, this won't work on the newer models with the pump in tank setup...
Ford whiz kids :mad:
1 - 5 of 5 Posts
