1 - 8 of 8 Posts
loud and long
got a 99 7.3 with stage 1 hypermax injectors. throwing injector code on 2 and 8. moved injector 2 to 4 spot and 8 to 6 spot to see if it would follow the injector and it didnt. also has an idm fault so swaped idms and code is still poopping up. so i then put a new injector harness on pass. side with the problem and still no change. any help will be helpfull. thanks
loud and long
Sorry i got myself backa**wards. Also the idm code is p1316 IDM fault, then it passes the injector buzz test
Aren't those inj codes common on the new cps? Did you do the cps recall?
Electrical Nomad
i have had the same issue for year. it all started with new injectors. replaced harness, 3 idms, icp, ipr, sent off the injectors to be checked, and i still have a bad running truck. i hope you find the cause because i would like to know. i ran out of time and money on this thing and had to just drive it as is, and i am affraid it has made the problem worse. good luck and i hope you get it fixed.
loud and long
got it fixed. it ended up being the injector harness. the one i got to replace was bad also so luckily my buddy had a spare layin around. put that on and it runs great.even though parts are new doesnt mean there good, lol. Mayday,on your truck what is ur injector pressure, have u had the hpop checked out. also how many miles are on the truck
Electrical Nomad
Yeah pressure was good, I checked out my new and old harness and they checked out ok and looked fine. I haven't messed with it for a while have been really burned out on it lately. I will plug AE back into it and reopen the can of worms again.
loud and long
alright man good luck!!
1 - 8 of 8 Posts
