1 - 7 of 7 Posts
02 f250 7.3 only drips oil when i have the block heater plugged in. looking up from ground i see 2 oil lines (i think) and above that looks like a water pump (again not sure what its called) what oil could be leaking when the block heater is plugged in???? thanks
Hood Rich
maybe geta picture of the area???
after googlin pics, its either leaking at the oil cooler fitting where the o-rings are where it bolts to the block beside the 2 braded lines below. is it hard to remove the cooler? and to separate the tube off the elbo fitting?
i had to change the oil cooler on mine truck last winter and after looking at it i decided it would be alot easier to just pull the engine out
Hood Rich
:pointlaugh:
Village Idiot
I hate threads like these, i bet in a couple of days mine will start leaking.
How many miles do you have?
1 - 7 of 7 Posts
