1 - 2 of 2 Posts
I have a 03 7.3, I bought the truck with a 4” lift on it and have been told that to get the lift off and level it I will need stock leaf springs. I’m having trouble finding springs, at least some with lower mileage.
I finally found some springs with 150000 on them, but the guy recently sold the truck. He gave me a pic with the stamp on the codes, and I am hoping someone can help me verify what spring code these actually are?
YC35AMC
PPN2880
Also,
Is there an option of finding a level kit that doesn’t require me finding stock springs? Thanks in advance
Administrator
Pro comp 22210 or factory x codes from ford or sdtruck springs. Those both will level your truck. Just remember that when you lower the truck, you will need the stock pitman arm, track bar bracket, sway bar brackets or links, and shorter blocks.
1 - 2 of 2 Posts
