1 - 16 of 16 Posts
Who has the cheapest headers and are they worth it??
None are cheap and there are a lot better bang for the buck unless you've done everything else.
A Ghost these days...
Diesel Innovations makes them. Not cheap by any means.
Id spend my money on other things that would yield you more power for your buck, unless your just making stupid power like some of the others....
nvm on them then its just my heads are so rusty lokin and if i look in my wheel well all i see it a big ol rusty header. Also i knew it would improve something but if its to expensive forget it.
Get a set of stock manifolds have them cleaned up and ceramic coated and call it good.
Yes they are.
Back in Black
yes they are, mine sound great also! :)
Dead Member
Has anyone done drive pressure tests to find the pressure differential between OEM cast iron Manifolds and DI headers on a stock motor?
Is it possible to drop drive pressure and EGT and not make any power?
Back in Black
if your doing it for power its a waste
Back in Black
they say they help egts and spooling, i never noticed it, in theory they would. not 1000$ worth though
Would they make more sense with head porting? That in itself would likely mean you would be at a certian power level to begin with.
Lovin Life...
The sound is worth the money. Music to the ears.
1 - 16 of 16 Posts
