1 - 4 of 4 Posts
I'am looking at buying another 99 7.3 Truck. The Truck has 285,000,the guy says that it has a Ford Rebuilt Complete Engine Change 3 +Years Ago with about 45,000 on it. I found on here that the Engine #s are on the Oil Cooler Header.The #s on this motors Oil Cooler Header are 181573902 can you tell me what year it ? Thanks ,PAT
Here is the engine serial number break down for the forged and powdered connecting rods. Check you engine serial number on the valve cover build sticker or you need to look at the block where the oil cooler is bolted to it .
Start of production thru 1425746 are Forged Rods
1425747 thru 1440712 are Powdered Rods
1446713 thru 1498318 are Forged Rods
1498319 thru final production run are all powdered
Or you can break them then you know what you have-Ha Ha-Just kidding
The reason for the break in serial numbers is a "test" run to be sure there were not any issues with the powdered rods. Once the process was production tested the powered rod process was used until the end of production.
I would say it is one of the newer 7.3's. Deff PMR.
1 - 4 of 4 Posts
