1 - 20 of 34 Posts
My early 99 7.3 is falling on it face when I try to sustain 60 or 65 mph on the highway acts like its not getting fuel. just changed the oil did a turbo rebuild with 6fin billet comp wheel, new orings in hpop and lines/ although waiting on ipr kit to get here. found hole in ebp tube not here yet along with ebpsensor, cps, an map sensor fooler. an im getting codes 0381,0470,0478. I run a superchip 1705 does this on all settings and stock. can anyone please help?
Discussion Starter #2
also my wait to start light isn't coming on I can tell the relay is working though
whistle tits
First code is a glow plug issue. Check all your fuses, make sure your gpr has voltage to the terminals as a start. The other codes are for your ebp sensor
I have 12.48 volts coming through the relay
would a failing cps make it run like this?
whistle tits
There's such a number of things that can cause a 7.3 to run rough, its hard to say. How many miles on the truck since you had hpop off truck?
50 at most
Sounds like a back pressure issue or a cps issue
FORD..THE ROCK CRUSHER
take your super chip out till she starts running right....that's will rule out the chip and make diagnosing things a little easier..
chip out still doesd the same thing runs great until I try to sustain 60mph or so. and the wait to start light not coming on has me puzzled?
sounds like a blown fuse...
all fuses in cab and under hood good? think it is possably fuel pump not keeping up?
Discussion Starter #14
do yall think its my hpop that cant keep up? maybe
your other codes are for back PSI.. have you cleared codes and run it yet??? did you fix that EBP tube yet?? what kind of boost fooler you running??
Discussion Starter #16
more updates coming Wednesday. I hade to order ebp sensor n tube, stage l&ll ebp fooler, also got dual relief map and boost fooler. all from dfuser. all should be in Wednesday and we will see I also noticed today that the plastic collar on the ipr is buggered up so that got ordered also. will update ya'll Wednesday. thank you for the help.
I would check the fuel pressure to start.
I had to put over 300 miles on mine after replacing the hpop to clear all the air out of the lines. My main problem was a hard start until the air worked out of the system.
Village Idiot
When was fuel and air filter changed.
have you done any tank mods or cleaned the in tank screens...
could it be a boost leak
Discussion Starter #20
I think one of my main problems was I had never changed the hpop oil. I bought truck in 99 it was 3 months old it now has 287,000 on it. have had no problems other than cps, gpr, turbo at 180,000 and waterpump until this episode. is their a good way to completely drain the high pressure oil system? is their anyway to get the oil out of the heads? the fuel filter is clean but when I was starting it after the hpop reseal and turbo rebuild the fuel pump was taking spells of not pumping fuel into the bowl when I cycled the key. so new fuel pump going on tomorrow. thanks for all the help guys. PSN RULES!
1 - 20 of 34 Posts
