CODE p0087 comes on and reduced power at wot after installing sands disaster prevention kit. I’ve replaced fuel pressure regulator., injection pressure sensor., fuel vacuum control valve replace both filters and checked filter on rail there is no metal shavings., and no metal shavings on top of cp4 pump with vcv removed I don’t think it’s a injector leaking issue because it dosent misfire or idle rough and there is no injector codes or smoke at all with throttle applied., my fuel rail pressure is around 4500 at idle the only thing I can think of is when I didn’t install that one smaller oring on the tip of sands bypass block initially I ran truck for 3 min and it threw a high fuel rail pressure code idk if I damaged something running without that o-ring for a few min Mabye the high pressures might of destroyed a valve in my cp4 high pressure fuel pump i or there was some debris in the lines of the kit sands gave me that entered into my fuel system. The only thing I can really rule out replacing right now is cp4 pump even though there is no sign of premature wear or a plugged line somewhere or screen somewhere I’m gonna take it to dealer if worst comes to worst for them probably to tell me what I already know I can’t afford there 1000’s of dollars in software to inspect all the electronics
