1 - 14 of 14 Posts
Strokin since '94
Curious if it was possible to put a 6.4 setup on a 6.0? I could get a tow setup for a good price from a buddy but nobody around here knows too much about turbos :confused::confused::confused: turbos are a new world for me
Strokin since '94
Would it just be too much hastle?
BRING DA AMBALAMPS
yes...for the money you spend, you could get something tried and true like a 64 or 66mm single.
Banned
64/72 over s480/88 compounds. You can find both chargers used for under 1k, and you wouldn't have to have a stand alone vgt controller or have the hassle of the 6.4 uppipes.
StackinChipsLikePringles
Definately more headache than Aleve there...
I'm no 6.0 expert, so what kind of back pressure issues would you have on a 6.0 with a compound setup. The 6.4's are horrible for it so its just a simple question for the 6.0
Depends on the exhaust housing
Compounds for under 1k?
Banned
I said each turbo can be bought under 1K. 1,000+1,000= 2,000 or less. I know I can have a s362-366 brand new for under 999., and I see s480's for sale all day for 600-900. The piping is the cheapest thing IF you can do it yourself. the Oil drain/feeds would be less than 100-150 bucks as well..flanges, mounting the s480, I think it could be done under 3,500, but of course a pre made kit or a shop would charge you 7K+. Excessive backpressure on 6.4 twins is primarily caused by a vgt high pressure charger and would be considerably less with a non vgt high pressure on a 6.0, say a s364/72 with a .76 t3 divided (diverter optional) with a s480/88 1.32 t6 or 1.10 t4, the t6 are alot more common and alot cheaper.. I want to see more home brew twin setups...
Just trying to get my medical #### delt with so I can go back to work, then I will be doing a similar setup on a 6.0. Ever since I sold my 08 I've been going crazy without a truck
Sorry donzi, wasn't trying to question you, was just inquiring as to what you meant. I wish I could run a California street legal twin setup. I'm not interested to swapping out every two years. What turbos are out there that can pass as a stock looking turbo? Sounds like a good search.
1 - 14 of 14 Posts
