1 - 2 of 2 Posts
I have a 2008 f350 6.4. So, my 6.4 got a p006B code that would cause the VGT actuator to shut off until I cleared the codes (I know I never met anyone that has had that happen) Once the codes are cleared it will run fine till that code comes back and it does it again. I hooked up my svt monitor to the truck and everything read normal except for the EBPS which said it had 50 psi key on engine off and over 200 driving. Any advice welcome thanks you.
If the readings from your monitor are actually in PSI (some read in metric Bar or Kpa), then it indicates a problem with the Exhaust back pressure sensor or the tube/fittings that connects to it are plugged with soot.
1 - 2 of 2 Posts
