1 - 4 of 4 Posts
everything in cab works but no start i got the truck dirt cheap from a friend and has a dpf delete just does nothing when you turn the key. lights in the dash work and everything just wont crank and the battery is good
Unplug the starter signal wire and touch it to your battery, if it cranks over you have somthing telling the pcm not to turn the engine over. Get a scanner on it and pull the codes. If it does not turn over try turning it by hand with a ratchet, although I dont think you can really get to it with the fan shroud in there on a 6.4.. pull your starter, test that. Where are you located? maybe someone on here is near you who could help you out?
okay well it turns over when i put power to the signal wire. would a flashing red security light make it not start, it stays on for a couple mins then goes off.
1 - 4 of 4 Posts
