21 - 40 of 59 Posts
WWDD
Discussion Starter #24
That could be the case, i just had never seen anyone before feb post up their build date till then, mine was a feb truck as were quiet a few of other job 1s
Elite has/ had a core motor from I think 6/06 which was bought as a core. I'm pretty sure it ended up being used for mock-up of parts, as the block/ crank, some rods, and bedplate, as well as a handful of other parts were destroyed. I'm pretty sure it was one of the test motors, but that's only an assumption.
Thanks for the info.I'll have to check my build date but it looks like I have a job 1 since I have the shorter front valance and I've had to change the rad.
just looked at mine, build date was 6/07 i know the title says 08 model.
Only problem so far was a egr valve went out under warranty.
One of a kind
mine was built in 11/09. What job is that?
If It Flies, It Dies
Just looked at my trucks date and it is 02/07. I havent had any problems with the radiator or anything else on the truck. Everything has been runnign fine, I have put almost 12,000 miles on the truck since I have got it and everything is running great.
ok so im new to all this, im looking for a 6.4 and have seen a lot of 08s so i want an 08 at the oldest, but what job is the best or what year is going to be the best? I want to put a Spartan tune on after a while anything about that?
Super Sparky
The newest truck you can find will be your best bet. It will have all updates/repairs already done. Whatever you buy, have an Oasis report done at a Ford dealer to tell you any Ford service that was performed.
Thanks, any idea on how new it has to be for sync
Why does it switch back to job 2 when 08 were job 3?
21 - 40 of 59 Posts
