1 - 6 of 6 Posts
scottbilt95
new to the forum. have a 2005 f250 superduty with the following:
-egr update
-ficm update
-stc fitting replaced
-new egr
-66k miles
-oil changed every 3-4k
-sct tsx performance tune
was running fine down the highway today at about 50mph barely on the throttle. went to pass and pushed down on the accelerator pedal about 1/4 throttle and it felt like the engine popped/hicupped and then no boost. pulled over and checked CAC boots but everything appeared okay. limped vehicle home and noticed different colors of smoke (dark and light; sorry, i'm a little colorblind) when i pushed on the accelerator; more smoke with more throttle. check engine light has not come on. pulled out the egr but it looked very good. i'm thinking a turbo issue but with the low miles not sure. also, hoping the suddenness of the problem may be a sign of something. any help would be appreciated.
jeff
Fixing Broken Stuff
Check the MAP hose on the right side of the intake that goes to MAP sensor that is mounted on top of the heater box.
scottbilt95
turbo impeller shaft snapped in the exhaust side. just for grins the broken piece augered itself into the downpipe. disappointing....... much thanks for the advice.
jeff
Fixing Broken Stuff
Wow, thats interesting, was the turbo giving you any problems before? Maybe a P0299 code? 05's and up seen to be the ones that the VGT sticks and than need to be cleaned to fix them.
1 - 6 of 6 Posts
