1 - 20 of 40 Posts
Ok so it sounds like there are problems with almost every type, of aftermarket fuel pumps (Lift) out there so what should a guy get?
Im going to feed Casserly 190's w 75% nozzles. Will install a regulated return as well at the same time, most likley stricktly diesel RR.
Lets here some pro's & cons, failures, success rates ect. about them all.
I still like FASS, the 150 i had on my blue truck for 4yrs is now on my dually. Been on there for a year now with no issues, got a 220gph on ol blue now with no issues. Tyler and a few other budddies have had great luck, although there are lots of guys who have not. But my personal experiances have been good with fass
I went through 3 FASS 150/180 electric motors...
Went back to a Aeromotive Marine grade pump, DAHL 200 water/fuel separator and filter, Aeromotive filter after the pump, "Y" block, AN fittings in heads, Aeromotive Marine grade regulator, fuel cooler...and the HELLMAN sump.
Whatever you decide to do...get the sump!!!
Premium Member
Running the AD 100 here with no issues to date. Don't be a chump, get a sump!!
Not to hijack but what exactly is a sump? :shrug:
<-•DEISEL CRAFT•
IV GOT A AD2 AND TSD SUMP and rnr form sinister or what ever that company nam is now
iv had no problems
I run the FASS 150/180, and the HELLMAN sump... to RCD 155s and I am happy...I did go thru a couple FASS motors, but the warranty is very good.
I have fass 150. Been thru a few motors but they always replace them. Been happy with it. I would recommend getting a spare motor to keep in the truck though.
Discussion Starter · #12 ·
Thanks gents, definitley appreciate the input from the experiences. It was a hard choice for sure, but i bit the bullett and went with an Air Dog II, hopefully i get a good one, however i think most of the issues that people have had with them have been running them out of fuel (the old 1/4 tank slosh routine) As far as a sump goes, im still debating whether or not i want to handi-cap my truck with one or not, im very leary on the position of them in relation to the area's i use my truck in. (See Canadian oilpatch in the dictionary) LOL.
Premium Member
Mod the skid plate and your sump is covered.
Premium Member
I figured adding a 1-2" spacer would do the trick. IIRC the mount bolts are long enough or just replace them with Grade 8.
Discussion Starter · #17 ·
Im gonna measure a 2.5" drop just from the looks of them, i think though so theres some wiggle room in there, depending on the depth/builder of the sump plate as well.
Premium Member
No one would ever know till they got a real good look at the tank. Well with 10.5" with 41's I guess everyone would see the skid plate...... :LOL
Premium Member
Sounds good. Post up pics if you get it done.
Discussion Starter · #20 ·
I will i just ordered the Hellman sump, i have some ideas about a custom line too so hopefully it turns out sweet.
1 - 20 of 40 Posts
