1 - 5 of 5 Posts
04 6.0 will not crank over. SCT can not comunicate with pcm. All fuses are good and battes test ok. Ran last night and today nothing. Any help would be great.
Haters Gonna Hate
unhook the pcm, and simply plug it back in, make sure to be very careful and not bend any of the pins inside the pcm side of the connector, mine did this a few months ago and thats what i did to get it goin, havent had a problem since
Already tried that. No change.
Also tried the pcm relay. No change.
Haters Gonna Hate
check the fuse for your obd2 port
Discussion Starter · #5 ·
Found that the PCM died. Took it to the shop. Found power and ground at the PCM good. Able to talk with all other controlers but the PCM.
1 - 5 of 5 Posts
