1 - 13 of 13 Posts
wiredupfiredup03
I have a 2003 f-350 with the early 6.0L engine. I replaced the starter a year ago due to the starter rod turning but not engaging the flywheel. The new starter did the same thing however it would only do it on cold starts, and after 2-5 tries the starter would engage and start the truck. Also on 80 plus degree days it would start first time even if engine is cold, but if its 50 or below it takes a few tries. I turn key for start and I hear the starter rod spin but not engage flywheel, I will stop for a few seconds and try try try till the starter engages flywheel and it starts. All mechanics i show it to are stumped and i need help, also flywheel was inspected with no issues.
Banned
Its possible you could have gotten a bad starter.
I had one a while back whee the Bendix would not also slide out. I took it back to the ford house and they gave me another one. New one has never had a problem.
Fixing Broken Stuff
^^ Me too
wiredupfiredup03
Yeah but the old starter did the same thing and new one does it when its cold outside, however it could be -10 out and as long as the truck is warm from running recently it will have no issues starting on first try. What my guess is if it could be solenoid going bad?
wiredupfiredup03
Ok when its cold that is when starter spins but no engage until I cycle a few times and then after about 2-5 tries it will engage and start, I will drive it long enough till engine temp gauge moves a little and turn it off (a quick drive to local store), I will then start it first try no problems. Its as if engine temp and outside temp determine if it will engage on first try. Weird i know.
Administrator
well if the starter is spinning the bendex action should chuck the gear out and engage the flywheel
even if it were a tad slow spinning for some reason
but you can try the solenoid or replace the starter if it has a warranty swap it out or at least that's how I would proceed
I Agree with the others responses. Only issues I've ever seen with starters related to temps is the starter overheating and not functioning properly. Can't say as I've ever seen one function incorrectly due to cold weather. If I were to think cold weather would effect anything it would more than likely be the batteries. It should be warrantied if purchased recently so pull it off and take it for an exchange. At most if it doesn't fix the issue you're out a lil time, oh and maybe a busted knuckle or two.
Jackleg Mechanic
Maybe oil is somehow getting in/on the bendix or somewhere in/on the starter and causing a restriction of some sort. Cold oil thick, hot oil not so much.
Just a thought.
My 2004 has the same issue:
Starter history: broken bolt at 100k, replaced starter 120k, repaced stater again 240k. 315k. Clunk no engagement replaced stater, replaced batteries and repaired passenger side + terminal clamp - corroded cranked. Ran fine. 3-4 weeks later weather got cold. Now. First try no engagement sometimes a clunk and spin sometimes spins without clunk. Startes if plugged into block warmer. Starts if glow plugs cycled several times or is has run for a few minutes.
Had an oil pan leak. Oil was on the stater. Fixed the leak but cold start issue remains?
Stater is a rebuilt from Advance auto. Batteries are standard Wallmart matching specs.
About to replace the starter again. Note: I had to loosen and reposition starter wires. Was shorting/ Hotwire starting after installing starter #3 the first time. Starter 3 is under warranty.
Any trick on the top two bolts? Blind removal and installation isn’t fun.
1 - 13 of 13 Posts
