1 - 5 of 5 Posts
Can the filler neck be removed from the valve cover without taking the valve cover off? If so, how does it come off? The neck will turn slightyly, but I don't want to break it, so I thought I would ask here before I get to carried away and tear it up. Thanks in advance!
It unscrews from the valve cover. Has the same threads and oring as the cap so you can screw the cap down in its place of it does break. The tube is plastic so it'll break before the metal valve cover.
Auto guide sucks
I unscrewed mine (with a big f'in adjustable wrench) and it didn't break, and I'm usually the master of destruction.
1 - 5 of 5 Posts
