1 - 3 of 3 Posts
So, it turned out to be my IPR valve was bad. It's now fixed and running! On the other hand. I found that my Y pipe is cracked and I have 3 dead glow plugs. My saga continues. Lol
food for thought on the Y pipes, i am going to be installing a three or 4 piece y pipe today by BD. looks like it will make the job easier then a standard y pipe. ill let you know how it goes. (install will be with cab on, turbo removed FYI)
That would appreciated. I knew I had an exhaust leak. But I thought something didn't seal up right from when I replaced my hpop. The flex joint on my ypipe probably cracked during that whole process.
1 - 3 of 3 Posts
