I have an 05 with 360000km on it that quit on the highway with a bunch of white smoke coming out the pipe until it rolled to a stop and wouldn’t start. For a few attempts it would billow white fuel smoke out the pipe but not start.
On my AE it passes injector buzz test, ICP is good spikes at 1800 drops down to 1200 while cranking. Cranking RPM of 160-170 with occasional spike up to 230. When I brought it in the shop originally I had cmp/ckp sync and ficm sync so I thought possible bad lifter. Pulled glow plugs out and did comp check and all cylinders were good at around 360-370 PSI. All rockers going up and down as they should. Put it back together and retried and wouldn’t start. No cmp/ckp sync or ficm sync with a p2614.
Ohmed wiring from PCM to cmp and checked shorts to ground and voltage. All checks were good. It ohmed out good and sensor ohmed out good. Pulled sensor, bore scoped cam pin and it looked good. Checked Hz reading at PCM for cmp and it checked out good at 1.3 hz and would spike pulses of 0.2V(I think that was the number) every time the cam pin would cross the sensor. Load tested the circuit from sensor to PCM with an old headlight off an f150 and it light up good and held while I wiggled wiring to see if it would go away. Installed known good PCM and FICM. No change. Installed new OEM cmp sensor. No change. Moved onto ckp sensor and wiring. It ohms out good, short to ground and voltage tests prove fine. It produces 160 hz at the pcm. Pulled sensor out to check tone wheel. Cranked engine over while watching ring and it seems to be running true. Hand cranked it while looking at every tooth and it appears fine. Tried moving it with a screwdriver and it appears tight. I have not replaced ckp sensor as it tests out fine and I know they are rare to fail but I just ordered one to rule it out. My thoughts are maybe the tone ring slipped but is still fairly tight on the shaft and I can’t get it to move on the crank.could this happen? Does anyone know how to check the tone ring timing with out an oscilloscope? I know that would be the best way but I don’t know anyone that has one and don’t want to pay ford to do it as money is tight right now. If I have the missing tooth spot at the cam hole is that supposed to be #1TDC?
