1 - 20 of 100 Posts
Hey folks, new to the forum, having trouble with my new to me 2003 6.0. I’ve been lurking around trying to find the issue on here but haven’t had luck.
Ive got a 2003 6.0 in a F250 with 208,000 miles. I’ve got no power before getting to 2500 rpm.
The motor is stock with no mods but it did come with an SCT tuner. Once I get passed 2500 rpm it’s got plenty of power but blows a lot of black smoke. It starts fine and idles alright. No white residue by degas cap.
Things I’ve tried:
removed the egr valve and cleaned, cleaned out port, replaced orings. It actually was pretty clean Compared to what I’ve seen online.
inspected the air filter, and even removed for a short period to see if there was a change.
inspected the map hose for cracks/leaks.
reset tune to factory, then “street”. No change. Set tune to performance, which helped slightly with low end power, but now blows black smoke during any acceleration.
Boost according to the sct is -1.5 or so during idle and gets up around 5 psi at 3000 rpm.
no codes are being shown.
What do I need to do next?
Thanks in advance!
Everyone always says that. Do more reading under the direct issue you are having. I'll give you two hints, one you already answered below. 2. Vgt
"resident smarty pants"
What are you using to read codes?
Oh buddy, I hear ya. Believe me. The tricky thing is I’ve seen this similar question asked a million times on various forums, but there is almost never a conclusion. People don’t come back to say what the fix is, or it was one of the issues I checked. I’m not like those other girls I promise...
I’m assuming the boost measurement isn’t to be Trusted since negative values should be un- possible?
I'm pretty sure the map can read vacuum.
Donuts to donuts your unison ring is stuck/worn. Possibly bad actuator or plug.
  • Like
Reactions: RedBearded1
Agree w/ above, but also the SCT is a VERY bad code reader. I don't think much of the Innova either.
ForScan Lite to a smartphone (with an OBDII adapter) will put you miles ahead.
  • Like
Discussion Starter #9
Hey man that’s super helpful. I’ll look into those things soon and report back.
Okay so I dug in and removed the turbo, and disassembled it as far as the unison ring. It moves freely by hand, like, with a finger. It’s pretty clean looking other than soot. No real caked on deposits. The hole for the cam/ pin deal looks good. Not worn at all.
Measured resistance of the vgt solenoid and it was 3.8-4.0 ohms.
I’m guessing this turbo must have been recently removed/ cleaned as that pain in the ass mounting bolt at the back was not there. Searched for that bigger forever before discovering that.
the shaft on the turbo spins freely and doesn’t have much play in it at all.
what’s next?
Start looking for boost leaks
Did you check the ebp?
Do you have a scanner like torque pro?
After those I'd probably try to get a cyl contribution test
You have a boost problem, it's either your losing the boost from a leak, bad turbo vgt control, or your injectors are not doing their part to make the exhaust engery.
Check the plug going into the vgt solenoid. Come down the harness a little ways.
Discussion Starter #15
So I think I’ve found the issue. At about 2 am after searching around I found that there is a loose connection where the exhaust manifold connects to the pipe going up to the turbo. Like, real loose. Trying to weasel my way in to tighten that now but it’s a real mother. I see why the last guy didn’t do it.
Yes that would do it, there's a recent thread about vgt problems that very detail putting that together. It's tough
Discussion Starter #18
Exhaust manifold is now securely bolted to the up pipe( I believe that’s what it is). Took it for a drive, boost will now reach up to 15-16 psi if I’m really givener but low end is still gutless and runs at negative boost. Vgt cycle according to the SCT sits at .68 at idle and goes to about .5 wot.
Vgt solenoid next? Is there any other places to check for leaks?
Discussion Starter #19
I checked the plug out. Followed the wiring back. Nothing visibly damaged. Tried disconnecting the vgt solenoid plug to see if there was any change. And there was. Much worse. So I’m thinking the solenoid/plug must be alright.
Since the up pipe is so tough, get a friend to rev the motor and stick your hand back there and check for a leak at idle and up to 2000 rpm.
I think it's not on the turbo, check for boost and exhaust leaks. Did you check out the ebp sensor? I would give it a good power brake and see if you get to 20 psi boost, look at the exhaust for smoke.
1 - 20 of 100 Posts
