1 - 20 of 40 Posts
What kind of truck? My 250 with 35's and 3.73's gets 13.5 city...
Monkeys have armpits!
need more info on your set up to compare too
with my 4.5" on 36"x15.5" tires with custom SCT tunes, i get around 15-16 mpg's
40 lug nuts
No, 8 mpg is definitely not average unless you're always pulling a heavy trailer or are on HUGE tires (like 46's, and even then you should get better than 8 mpg).
i bought the truck with the lift and it has head studs and i didnt kno if they put injectors or anything else in it
thought about that ive been told about sct, a bumch of my friends are running ts chips so not sure wat one i want to get
TS=7.3. SCT=6.0. Does the truck smoke alot right now? Do you have any gauges?
What are you seeing for EGT's while cruising?
That is way high, what you seeing for boost cruising and WOT?
1 - 20 of 40 Posts
