1 - 13 of 13 Posts
<-- it's like that
The 6.0L intercooler will bolt in, but you'll need new boots to connect the I/C tubes to the I/C. You'll need one 3x3x8" and one 3x3.25x8" boots, and one new 3" clamp to make it all work.
Can I jump in here? Will it cause any lag with a stock E99 turbo?
no lag. had the little stocker before i switched. no problems. lowered egt by about 75 - 150.
There's a place that sells the boots for that conversion but I'll have to do some searching. If I find it I'll post it.
<<< THE GAUGE WHORE...
If you dropped 150* with a 6.0 IC swap you had a boost leak...
I saw less then a 50* drop empty, and maybe a 50* drop towing... MAYBE.
Huh! I'm not doing all that work & spend the money for 50*
I am in the same boat, so is it even worth doing? Also does it matter stock vs modified motor for any results?
1 - 13 of 13 Posts
