1 - 6 of 6 Posts
m-chan68
does cam need to be removed to replace rollers
If roller lifter(s) need replacement, so does the cam. Just the cam by itself, is an ENGINE-OUT repair on a 6.0L. While you're at it, you better retrieve the broken pieces before they pass through the oil pickup tube and do further damage.
Pulling sled for hire
I had a lifter go bad and eat the cam. Bean's handled my repairs and found some material in the oil pan. They had a customer before me who had rollers out of the oil pan get picked up and it took out the lpop.
I've replaced several lifters with no damage to the cam, it depends on what the failure was. If a lifter spins or the roller seizes, then yes cam damage usually happens. I've had several lifters where the retainer for the lifter plunger breaks and the guts came out of the lifter with no damage to the cam.
m-chan68
My point exactly.
1 - 6 of 6 Posts
