1 - 6 of 6 Posts
just for fun
Will bare wires on the ICP pigtail cause the sensor to short out and the truck not run?
just for fun
Sorry looks like I need to set up a sig on there.
Its an 03 with a 6.0. the icp was changed out 2000 miles ago. Went out to fire the truck up and it fired chugged then quit. Codes pulled showed icp so I looked into it and found a crappy job done on the pig tail switch and then the connecter was soaked.
I Just Break Stuff
Sounds like you may have found your problem then.
m-chan68
Okay, here is the perfect example of why I always replace the sensor AND the pigtail connector (which is updated to by the way).
1 - 6 of 6 Posts
