1 - 4 of 4 Posts
My dads 2007 6.0 is having issues starting, it has new batteries, and a rebuildt FICM by Ed at ficmrepair.com. If its below 25* outside the truck turns over for awhile and start but smokes more then a normal amount of white smoke and almost sounds like it has a slight miss. The FICM voltage stays above 48 volts when starting and the batteries are putting out around 12.5-13v. He has been running rotella t6 since its been bullet proofed in march of 2012. Any help would be great.
Mods are: ARP head studs, OEM gaskets, new heads, larger oil cooler, edge CS, coolant filter, knn intake, 4" exhaust, repaired FICM
Ford replaced 5 injectors so 5 have less the 20,000 miles and the other 3 are factory with 107,000 miles. Check the glow plug relay which was good but not the glow plugs them self, they were check and working in march of 2012
1 - 4 of 4 Posts
