1 - 12 of 12 Posts
AllYourBaseAreBelongToUs
Is there a way to tell if a 6.0 trans is from a 4x4 or a 4x2? I'm gonna be getting a trans built here soon and I have one sitting here to send so I don't have to have my truck down while it's being built. But I don't know if it's out of a 4x4 or a 4x2.
Or does it even matter?
Don't EFN worry about it
Ouput shaft area is there about a 5" hole there were the t case goes??
Corona Killa
2wd well have a different tailshaft housing and will look complete without a
t-case.
It matters but you can have either one built built. Then when you get it built stand both trannys up on the bell housing. Then pull the output section off one and swap it to the other one. I have done it.
By y'alls description sounds like I have the 4wd. :rockwoot:
Here's some pics just to verify:
Yes, that is a 4wd.
Where are you sending it Danny?
David at Diesel Innovations.
1 - 12 of 12 Posts
