1 - 4 of 4 Posts
KyleMaras7.3LPowerstroke
7.3L with shift on the fly. I would really like to know what this could be. My buddy and i tested it at the t-case and nothing. We think it is the 4x4 relay above the glove box. Is there anything else i should consider before buying the $300 relay???? For ####s ill turn the switch and the light comes on and 4wheel works. But 95% of the time nothing. WHAT ELSE IS THERE???? Please help! The snow is right around the corner
blame the dog..
if the light doesn't come on when you flip the switch, I'd be checking the relays.. but they're under the hood and they're not $300 (at least on mine)
Diesel Sled Head
Are you sure the tcase is engaging the front shaft. Have seen many issues with the hub seals in the front end.
Im able to manually lock my hubs. Where ae the relays at under the hood? The only one i know about is above the glove box. Its about 4"x6" in size, pretty good size.
1 - 4 of 4 Posts
