1 - 3 of 3 Posts
I have an 04 f250. The problem I got with the 4x4 is it will lock in if you put the hubs in lock, but if it is in auto the hubs wont engage. I think I got a vaccum leak, but was wondering where I need to look to get this problem fixed? Thanks in advance.
BUILT NOT BOUGHT!
When you try to engage the hubs via the switch does your heater automatically go to defrost & stay there ?? thats a first sign of a vacuum leak.
First place I would look is the vacuum hoses under each front wheel well that go down to each front spindle & slip over a small fitting on the front side of the spindle
make sure either one has not cracked, torn or fallen off. Replace if so.
Next step is replacing the big ( 4" ) vacuum seal in the back or each hub, you can not see it without first removing the wheel bearing.
Hope this helps!!
K i will have to check it out when I find some time. Dont use 4x4 much since I am in the hill country of tx and we dont get much rain. Just noticed it the other day when it actually rained for the first time in a long time. Thanks
1 - 3 of 3 Posts
