1 - 2 of 2 Posts
Hello,
And yes I am new here! I have a 2001 F-250 SD 2-wheel drive Extended Cab Short Bed with a 7.3 Turbo Diesel and the 4R100 Automatic with Overdrive.
The truck has been sitting for a while because the transmission refuses to upshift from 2nd to third.
The truck has about 190K miles and I am debating on whether to break my bank and go for a remanufactured transmission or taking into a reliable shop and have them do a diagnostic on the transmission and see if there is something simple that can be done?
I read that the valve body may be the culprit with the 2-3 valve being stuck? I have never had the pan off the trans or any service to the trans since I owned the truck as the 2nd owner.
What years of transmissions will be identical? Is is 1999 to 2004? I thought the 7.3 Turbo was phased out in 2002? (anyone know?)
A reman trans is going to run me close to $3 grand. Not sure I want to put that into it but then used transmissions scare me!
So....What are your ideas here? Thanks! Bob in VA
190k and you have not had the pan off isn't a good start. If you're in Alexandria like your signature says.. take it to Superior Transmissions in Silver Spring, MD. Very good service and very reasonable prices. They have done 3 different trucks for me with 4R100 and E4OD and always stood by their work and very good people to deal with
1 - 2 of 2 Posts
