1 - 2 of 2 Posts
I have a 96 single cab i recently got 40 20 40 seats out of what i believe was a crew cab. Got the seats for 80 bucks so it was a deal i had to get it. As i read and notice the CC seats dont have the main floor pan that the SC 40 20 40 seats will bolt to. Each seat is all separate and on the bottome of the tracks there are studs where nuts will go into a mount to be bolted. Anyone ever put CC 40 20 40 in their single cab? I need some insight on how to make it work or how to make mounts. Thanks
Sounds like you have seats from an extended cab. The floors are different in an extended cab compared to a standard cab or a crew cab. You need to find a seat pan from a standard cab or crew cab and also the metal base for the center console is different. Your seats will bolt on to the seat pan once you remove the extended cab seat brackets and like I said you need to switch the metal base on the console cause there a little different.
1 - 2 of 2 Posts
