1 - 11 of 11 Posts
Can anyone tell me if the 38r has a hook-up to connect to the truck's cooling system?
I know the Garrett instruction manual does mention something about a catch basin for coolant, but then I don't think there are any steps of the instructions that actually deal with connecting a coolant line.
Thanks for any help.
OEM Moderator
No it does not.
Lovin the Tuna
It bolts right in place of the stock turbo. It is cooled by the engines oil that passes through it, just like the stock turbo.
Thanks for the replies, that's what I thought.
Is there anything involved in coolant lines at all during the install? Do you need to disconnect any coolant lines to get the turbo in?
Lovin the Tuna
nope, nothing with coolant lines. You will disconnect the air intake tube from teh turbo, the intake spider, the uppipe (from the exhaust on back of turbo/motor) and the down pipe (exhaust leaving turbo on passenger side). Also the little accuator arm for the exhaust backpressor, and 2 bolts on the top of the turbo. It really goes fairly quick and pretty cut and dry. once you are in there you will see how simple it actually is. Just make sure you spray some PB plaster on all the clamps the day before or morning of, it will help a LOT.
<-- it's like that
Nope, nothing.
The 38R is a direct bolt on replacement for the stock turbo. Simply disconnect the up-pipe collector, downpipe, and intake tube from the turbo. Unbolt the turbo and pull it out. The new turbo bolts in exactly the same way.
With a new 38R, you'll probably want to load the wastegate actuator.
Here's some instructions for removing the stock turbo and installing the 38R: http://67.19.132.3/dieselinnovations/www/techfiles/gtp38r_installation_instructions.pdf
Nope, nothing.
Cool, thanks for the replies. Again, I didn't think any cooling lines were involved. The instructions just threw me off mentioning a catch basin for coolant as one of the "tools needed". I'm sure it's just part of the same instructions they use for a lot of different turbos.
Lovin the Tuna
Did you get new o-rings? I would recomend replacing them while you are in there.
And nice link pocket, definitly very good instructions there.
Lovin the Tuna
Ahh, good stuff. Make sure you get 2 sets of o-rings then. The pedestal to motor and turbo to pedastal both use the same pair of o-rings.
1 - 11 of 11 Posts
