1 - 8 of 8 Posts
Planning on putting 35's on the stock 20 inch wheels with a 2.5" icon stage 4 leveling kit when I get my truck. I talked to the dealership and they said they can adjust the speedometer within 'Ford's parameters'. I am not planning on getting a tuner, so my question is has anyone had any experience with having the dealership recalibrate the speedometer? Does it make your mph spot-on or is it still off a little bit?
Also, the dealer mentioned that the tire pressure indicators should be ok if I stick with the stock rims? Is this true with bigger aftermarket tires?
1st murdered 2011 psd
My speedo was actually reading a few mph faster than my actual speed before and now with 35s it's dead on w gps... Also it's not the size of the tire, it's the max cold that matters on the tpms...
Same here, dead on with 35's.
Mine is actually off quite a bit. When my speedo shows me doing 70mph I am actually going 74mph via gps. I plan on having the dealer re-calibrate when I bring her in for the first oil change.
I had stock 18's and went to 35's on 20's.
ya mine came stock with the 18s 3.31 gears and now im running same gears just 20s and 35...
Mine came with 18's and I have the 3.55 elec locker. It is dead on gps.
Discussion Starter · #7 ·
Good to know. I'll drive it around a bit before I have them reprogram anything.
I know with the TPMS it goes by the cold psi, but can they not reprogram it to a lower psi for the aftermarket tires?
Discussion Starter · #8 ·
Just saw a thread where TPMS question was answered in technical info forum. Thanks.
1 - 8 of 8 Posts
